Absolutely!
Just make sure you put a layer of LIQUID NAILS LANDSCAPE BLOCK with polyurethane - or a similar OUTDOOR / LANDSCAPE type adhesive that contains POLYURETHANE.
The poly allows the adhesive to have a little give… so they can move a little bit on those cold winters or real hot summers. Rock hard adhesive will simply crack / break after the first winter.
