I am curious to see how folks are mounting their cook utensils. I wanted to mount a rack on the side of my oven but am hesitant to drill into my brick. I cant use the outer sides of my base because I have built countertops off each side. I could mount underneath the over but that is where I try to store my wood. Just curious to see how others have mounted racks/brackets for their cooking utensils.
Great question, Jeff, and I’m curious as well.
It’s a straightforward process to drill holes and set anchors in the frame bricks. You do need the appropriate drill bit and anchors, though. I recommend TapCon drill sets and anchors for that, and the one caution that goes with it is to avoid making the anchor hole any bigger than it needs to be. If you do that then the TapCons won’t work (and don’t ask me how I know
But again, I’m curious to see what others have done, because there are many creative builders on these forums!
Yea, I was planning on using tapcon screws to mount whatever I do decide on using. Just curious to see what others may have done before I commit to drilling into the brick. Was thinking maybe even a small U bracket type shelf with 3/8" black pipe mounted to the outter oven base may work as well. Just spitballing now.
Excellent! (Don’t worry about my spelling out the obvious…I’m sure you know what you’re up to, but we try to add more explicit information for first-timers who might see that nice rack in the accessory kit and wonder “now how do I get that to stick to the oven?”)
If you’ve got the space on the sides then that sounds like a good alternative. My stucco comes out to within a half inch, so it wouldn’t work for me.
I actually made a shelf under the hearth in the top of the pedestal. By making it near the top, I can still store wood up to the shelf level and have a place to stow my peels when cooking.
I haven’t finished my oven yet so we’ll have to see how this works in practice but it was easy to do and does not require drilling into exterior surfaces.
Looks good! I ended up hanging mine in my kitchen and I just bring them out when I fire up the oven. I may still add something to hold them outside but I at least have a temporary solution.
LOVE IT! I just added that to our DIRECTIONS 2.0 file!
Someday, you will see this idea in our Installation Instructions as an option.
WONDERFUL IDEA!!
Thanks @BrickWood, this is my one humble contribution to this awesome oven and site. ![]()
