Hi
I am done veneering my oven and am in the process of grouting everything. Once done, I would like to use a masonry sealer. My question is, should I do the curing fires first, or is it OK to seal before the curing fires?
Thanks very much.
Greg
Hi
Thanks very much.
Greg
I’d recommend sealing before you cure. The fires are inevitably going to generate soot, and you’d have to scrub that off before you could seal.
And congrats on finishing the veneering step, Greg!
That makes sense, I didn’t think about the smoke and soot. My concern was that I might be interfering with the curing and drying process by sealing the barrel before the fires.
Thanks, the oven looks much nicer now that it is covered in brick veneer. I started grouting and used a grout bag for the first time. It is saving me a lot of time and effort. Such a simple thing, but so helpful!
Thanks very much Matt.
Greg
